Autor Tema: Hardware nuevo para C64  (Leído 187781 veces)
Dashiad
« Respuesta #360 en: Octubre 25, 2021, 11:50:50 »
Por lo que dice el titulo, y por donde está conectado, parece un reemplazo del chip de video.
Y..cuando he visitado la página del proyecto, efectivamente, es eso:
http://accentual.com/vicii-kawari/
VIC-II Kawari is my hardware replacement project for the VIC-II (Video Interface Chip II) found in Commodore 64 home computers. In addition to being compatible with the original VIC-II 6567/6569 chips, some extra features will also be available.
Me parece exageradamente grande para eso.
Aprovecho, y posteo aqui un link al Sidekick64, que me parece un proyecto que promete mucho:
https://github.com/frntc/Sidekick64
« Respuesta #361 en: Octubre 25, 2021, 13:44:01 »
Pero lo que no entiendo es porqué está junto con BMC64...¿? si BMC64 ya es todo un emulador en si mismo... no sé, algo se me escapa! :P
Esto parece que hace mil cosas...
Sidekick64 is a versatile cartridge/expansion for the C64, C128, and the C16/+4. Its functionality is entirely defined by software running on a Raspberry Pi 3 (RPi). The connecting circuitry is quite simple and does not include any programmable ICs. Currently implemented features include the emulation of
a GeoRAM/NeoRAM-compatible memory expansion,
freezer cartridges
Action Replay 4.x-7.x
Final Cartridge 3(+)
Atomic/Nordic Power (experimental)
KCS Power Cartridge
Super Snapshot V5
numerous bank switching cartridges such as
CBM80, C16/+4 and C128 cartridges
Easyflash (with simplified EAPI support)
GMod2 (inclduing EEPROM for save games)
Prophet64
MagicDesk/Domark/HES Australia
Dinamic
Ocean Type A and B (up to 512k)
C64 Game System
Funplay/Powerplay
(Super) Zaxxon
Comal80
Epyx Fastload
Simons Basic
RGCD and Hucky's cartridge
C64 kernal replacement,
Function ROMs on a C128, or
multiple SIDs and Sound Expander/FM emulation (up to 8 SIDs, e.g. to play The Tuneful 8)
simplified Datel and Sequential MIDI interface with built-in SoundFont-synthesizer (slightly modified version of TinySoundFont)
TED-sound and Digiblaster emulation for C16/+4 (to have all sound devices on one output)
But many more things are imaginable, e.g. 80 column cards with HDMI video output, custom accelerators/coprocessors etc.
Sidekick64 is a result, or cumulation, of the RasPIC64 project, which is the framework enabling a RPi to bidirectionally communicate on the bus of a Commodore 64/128. Currently, Sidekick64 is set up to work with a Raspberry Pi 3A+ or 3B+ and has only be tested with various PAL-machines (C64 revisions, C128, C128D), C64 NTSC, C16/+4 (PAL, PAL-N, NTSC). To the C16/+4 Sidekick64 is connected using a simple adapter.
Dashiad
« Respuesta #362 en: Octubre 25, 2021, 14:02:49 »
Donde aparece el BMC64?
Yo lo que veo es que lo está pinchando a una placa de éstas modernas, llena de cacharros que reemplazan los chips originales (creo que he visto el ARMSID, y cosas de esas)
« Respuesta #363 en: Octubre 25, 2021, 14:16:32 »
Quizás me he liado con este enlace:
https://www.patreon.com/bmc64?l=es
Ahí aparece esto:
BMC64/VICII-Kawari
está creando BMC64 bare metal RPi emulator & VIC-II Replacement Projects
Viendo el VICII-Kawari entiendo que es un reemplazo del VIC pero en ese enlace parece que fuera algo relacionado... ahí es donde me he liado.
Supongo que son dos cosas independientes.
Dashiad
« Respuesta #364 en: Octubre 25, 2021, 14:54:23 »
Ahh...Si, es el mismo autor, con dos proyectos diferentes..
Y me gustaría un BMC64...si tuviera todos los puertos originales..Entiendo que no tiene sentido como usuario (para que quieres un cartucho, si lo puedes cargar todo desde la raspi?) , pero para cacharrerar, sobre todo con cosas como los cartuchos, donde cualquier fallito de soldadura puede ventilarse el C64, tener una placa con una raspi y el VICE estaría bastante interesante..
« Respuesta #365 en: Octubre 25, 2021, 15:37:28 »
Hay unos cuantos pidiendo ese "puerto" para BMC64, lo mismo también soporte para spinner... pero parece que no es algo simple, al menos lo del puerto y como dices, existiendo los CRT es como que no tiene mucho sentido el esfuerzo...
En cambio lo del spinner sí que me parece interesante que estuviera.
« Respuesta #366 en: Octubre 28, 2021, 00:39:34 »
Interesantes estas placas/cartucho con formas:
https://www.pcbway.com/project/member/?bmbno=5B9D77D5-9033-46
« Respuesta #367 en: Enero 14, 2022, 15:07:16 »
Un simulador de todos los tipos de teclas que hizo esta gente:
CBMSTUFF.COM Indiegogo Keycap Campaign Color Simulator
http://www.retrokeycaps.com/
« última modificación: Enero 14, 2022, 15:09:29 por josepzin »
« Respuesta #368 en: Febrero 19, 2022, 15:06:26 »
1 Cartridge Plugs into 12 Vintage Computer Systems
https://www.youtube.com/watch?v=-V4XmkSOPcM
« Respuesta #369 en: Marzo 12, 2022, 16:00:10 »
No sé que hace esto... :P
Raspberry Pi Pico Becomes Commodore 64 Cartridge
https://www.tomshardware.com/news/raspberry-pi-pico-powers-c64-cartridge
« Respuesta #370 en: Mayo 11, 2022, 19:30:35 »
RasPIC64
- https://github.com/frntc/RasPIC64
- https://www.lemon64.com/forum/viewtopic.php?t=70589&start=45
RasPIC64 is a framework which enables a Raspberry Pi 3B/3B+ (RPi) to bidirectionally communicate on the bus of a Commodore 64. Example use cases of RasPIC64 are connecting the RPi to the expansion port where it can emulate a GeoRAM/NeoRAM-compatible memory expansion, a CBM80-cartridge, or run a Dual-SID plus FM emulation (the SID emulation would also work when connecting the RPi to the SID-socket on the board). But many more things are imaginable: emulating freezer cartridges, 80 column cards with HDMI video output, custom accelerators/coprocessors etc.
Update: I added an emulation of Easyflash and Magic Desk cartridges, reading .CRT files from SD card.
Re:Hardware nuevo para C64
« Respuesta #371 en: Mayo 17, 2022, 00:55:32 »
@Dozznar sustituye su SID en vivo!!!
Sustituyendo SID Estropeado por ARMSID
https://www.youtube.com/watch?v=HJrV86Ag8KI
« Respuesta #373 en: Mayo 20, 2022, 11:32:49 »
Esto no es nuevo pero tampoco sabía en que apartado compartirlo
Estoy haciendo una preservación de una cinta de c64
Como curiosidad y para que veáis el potencial de la placa Ultimate 64, estoy usando el Headalign para ver como está el azimuth del datassete, a la vez estoy conviertiendo la misma cinta a TAP y mientras puedo navegar por la ventana que podéis ver.
« Respuesta #374 en: Mayo 20, 2022, 19:46:22 »
No sabía de esa opción del Ultimate64, mola!
