Autor Tema: Hardware nuevo para C64  (Leído 187043 veces)
« Respuesta #345 en: Junio 14, 2021, 14:20:45 »
Dejo esto por aquí, un reemplazo de las RAMs del C64.
SaRuMan-64 (static RAM replacement with VSP Fix)
https://www.protovision.games/shop/product_info.php?products_id=255
« Respuesta #346 en: Julio 02, 2021, 16:56:55 »
Esto digamos que no es algo específico para C64, porque HEMULASION... :P
Commodore 1541/SD2IEC adapter for MiSTer
https://www.antoniovillena.es/store/product/commodore-1541-sd2iec-adapter-for-mister/
« Respuesta #347 en: Agosto 27, 2021, 13:01:17 »
Otro reemplazo del SID, creo que tendría que hacer un hilo independiente solo para los SIDs!
SwinsidNeat
- https://github.com/jsanpe/SwinsidNeat
- https://www.lemon64.com/forum/viewtopic.php?t=78328
Yet another PCB layout of the nano SwinSID focusing on aesthetics Nano SwinSID Neat
What is this repo about?
- A kicad implementation of the Swinsid Nano. Based on the nano SwinSID b design by Tolaemon
All components are placed on the bottom layer: the goal is to leave the top layer component free and use the silkscreen to mimic the MOS 6581 logo. So, this new layout has aesthetic purposes only.SwinSID
- The ICSP header is now optional: Some of the pins on the side have been repurposed to program the ATMega without the need to an additional 2x3 header, which contributes to a cleaner top. The required connections are marked in the PCB
The LED is placed on the top layer, mostly for visibility reasons (in daylight conditions it is easier to spot the led to verify power is reaching the swinsid). However, the led is fully optional allowing the top layer to only have the
« Respuesta #348 en: Septiembre 13, 2021, 22:03:03 »
Más reemplazos del SID!
Este (no me acuerdo los anteriores) reconoce los potenciómetros de los paddles.
BackSID Commodore 64 Sound Chip Replacement
https://www.youtube.com/watch?v=vhtraERrMNw
« Respuesta #349 en: Septiembre 13, 2021, 22:45:22 »
ARMSID sí maneja los dispositivos analógicos (ratón y padle). SwnSid no
« Respuesta #350 en: Septiembre 14, 2021, 00:03:54 »
Obviamente lo mas importante es que funcione bien la música, pero en mi caso sería imprescindible que tuviera soporte también para paddle. Por suerte todavía no necesito estos chips!
« Respuesta #351 en: Septiembre 24, 2021, 14:08:10 »
Este proyecto sigue avanzando: Keycaps for your Commodore computer!
https://www.indiegogo.com/projects/keycaps-for-your-commodore-computer
« Respuesta #352 en: Octubre 08, 2021, 04:23:09 »
Pi1541Zero – Convert your Raspberry Pi Zero into a full compatible 1541 C= drive
https://www.arananet.net/pedidos/product/pi1541-convert-your-raspberry-pi-3-into-a-full-compatible-1541-c-drive
Pi1541 is a real-time, cycle exact, Commodore 1541 disk drive emulator that can run on a Raspberry Pi 3B designed by Steve White. This board has been designed using the Steve’s original schematics. The installation is super easy. The PI goes behind the board, plug in into the HAT, put the SDcard with the required software and you are done 🙂
This new version goes directly to the IEC connector, no cable is required, the connector is soldered onboard. Also there are the iec signals available in case you want to build a cable for it.
This new version includes:
Custom Pcb (works with Pi Zero / Pi3)
2×20 2.54 connector.
3 buttons.
Levelshifter onboard.
128×64 Oled screen.
IEC connector included.
All the components are presoldered.
Ask for the sd files via email info@arananet.net.
This board does not include:
Raspberry Pi Zero ZeroW.
Micro usb cable required to powerup the PI Zero.
More info about the Steve White project, here: https://cbm-pi1541.firebaseapp.com
Some good friends help me with the reviews:
https://www.youtube.com/watch?v=aC2hYmPMNzM
« Respuesta #353 en: Octubre 13, 2021, 16:33:59 »
« Respuesta #354 en: Octubre 23, 2021, 05:46:00 »
No tengo muy claro qué es esto... :P
A new SuperHero: Kawari VIC-II for C64 (Beta Test)
https://www.youtube.com/watch?v=RB2yr_aVfHs
« Respuesta #355 en: Octubre 23, 2021, 10:16:53 »
Aquí lo tienes:
https://www.patreon.com/bmc64?l=es
Es un emulador no?,pero para el commodore 64 real.Me parece buena idea.
« última modificación: Octubre 23, 2021, 10:20:54 por alex »
« Respuesta #356 en: Octubre 23, 2021, 14:16:32 »
Sigo sin enterarme bien qué es esto... parece que usa BMC64 pero no entiendo cual es la diferencia o qué es la parte de ".../VICII-Kawari"
« Respuesta #357 en: Octubre 23, 2021, 15:06:27 »
Yo entiendo que es el emulador Vice insertado en un commodore real.Puede ser muy interesante si estoy en lo cierto.Todos los juegos en el chip,control de velocidad,poder jugar con el teclado y esto es muy interesante ya que tendríamos la opción de configurar el teclado a nuestro antojo.Ultimamente me da por jugar con el teclado,me gusta usar los cursores y es una opción muy interesante.Que me disculpen los puristas pero yo nunca lo he sido.
Si este chip se inserta y podemos cerrar la carcasa del commodore es una idea genial.
Sin modulos insertados en el ordenador,vamos,"sin cachivaches".Todo limpio,un commodore sin mas.
Si esto es así me parece la perfección absoluta.
En el caso del commodore real las teclas serían:I-K-J-L,podemos usar el boton de acción con la letra A y la barra espaciadora queda perfecta para su acción.Yo solo entiendo de esto,soy un jugón nato y esta configuración es casi perfecta.Tiene mucha precisión y es muy cómoda.
« última modificación: Octubre 23, 2021, 15:16:21 por alex »
« Respuesta #358 en: Octubre 25, 2021, 02:38:03 »
Si, es el emulador VICE metido en la carcasa del 64 usando una Rpi, y además arranca super rápido.
« Respuesta #359 en: Octubre 25, 2021, 11:40:46 »
Genial,muy recomendable.Imaginate solo dos cables.Corriente e imagen.
