Autor Tema: Hardware nuevo para C64  (Leído 187583 veces)
« Respuesta #270 en: Julio 29, 2020, 13:17:44 »
Es que el de la derecha, el "cartridge port", es hembra y en la imagen le falta el conector.
El "user port", que es macho, sí que parece estar, al menos el conector fisicamente, ¿quizás sea esto un micromachismo?? :P
« Respuesta #271 en: Julio 30, 2020, 19:39:52 »
Yo quiero!!
Testing the new SID player 🤘🤘
https://www.youtube.com/watch?v=_bBsGYvaXog
« Respuesta #272 en: Julio 31, 2020, 01:21:33 »
« Respuesta #273 en: Julio 31, 2020, 01:22:33 »
Pi1541Zero – Convert your Raspberry Pi Zero into a full compatible 1541 C= drive
https://www.arananet.net/pedidos/product/pi1541-convert-your-raspberry-pi-3-into-a-full-compatible-1541-c-drive/
Pi1541 is a real-time, cycle exact, Commodore 1541 disk drive emulator that can run on a Raspberry Pi 3B designed by Steve White. This board has been designed using the Steve’s original schematics. The installation is super easy. The PI goes behind the board, plug in into the HAT, put the SDcard with the required software and you are done 🙂
This new version goes directly to the IEC connector, no cable is required, the connector is soldered onboard. Also there are the iec signals available in case you want to build a cable for it.
This new version includes:
Custom Pcb (works with Pi Zero / Pi3)
2×20 2.54 connector.
3 buttons.
Levelshifter onboard.
128×64 Oled screen.
IEC connector included.
All the components are presoldered.
Ask for the sd files via email info@arananet.net.
This board does not include:
Raspberry Pi Zero ZeroW.
Micro usb cable required to powerup the PI Zero.
More info about the Steve White project, here: https://cbm-pi1541.firebaseapp.com
« Respuesta #274 en: Julio 31, 2020, 01:23:40 »
« Respuesta #275 en: Julio 31, 2020, 21:38:18 »
¿Alguien quiere este teclado mecánico retroiluminado? YO SI :D
https://www.lemon64.com/forum/viewtopic.php?t=75572
« Respuesta #276 en: Julio 31, 2020, 21:38:59 »
« Respuesta #277 en: Agosto 05, 2020, 19:53:20 »
« Respuesta #278 en: Agosto 08, 2020, 14:50:31 »
Alguien conoce este cartucho???? parece como una mezcla entre EasyFLash y SD2IEC, tiene buena pinta.
Kung Fu Flash – El cartucho definitivo
Su principal peculiaridad es permitir la carga de diferentes formatos desde una tarjeta microSD (formateada en Fat32).  Los formatos compatibles son :
- Disco: d64 / d71 / d81
- Programas: prg / p00
- Cartuchos: Crt
https://www.commodorespain.es/kung-fu-flash-el-cartucho-definitivo/
« Respuesta #279 en: Agosto 08, 2020, 14:56:38 »
PRODUCCIÓN Y / O ADQUISICIÓN
Si después de conocer mejor las posibilidades que nos da el nuevo Kung Fu Flash quieres hacerte con uno. Hay dos opciones, fabricarlo tu mismo o adquirirlo ya montado. Nuestro consejo es que si no quieres complicarte a menos que seas un gurú de la electrónica es adquirirlo a gente de confianza.
Por ejemplo es el caso de Jgilcas, cuyos trabajos tienen una gran calidad como hemos podido comprobar nosotros mismos en más de una ocasión. Una muestra es lo que hemos compartido en este artículo, pues este dispositivo ha sido fabricado por él. Así que ya sabéis, si necesitáis un Kung Fu Flash en vuestra vida no dejéis de consultarle.
« Respuesta #280 en: Agosto 09, 2020, 11:39:33 »
No conocia el KFF. Interesante, aunque no acabo de ver en que consiste exactamente. No parece tener un cable serie, asi que creo que no sea compatible con el SD2IEC. A ver si sale alguna prueba a fondo de el.
Eso si, los colores del cartucho parecen de pesadilla, no armonizan con el 64 ni con la mejor voluntad.
« Respuesta #281 en: Agosto 09, 2020, 14:01:30 »
Yo supongo que sería como un EasyFlash que además lee archivos PRG, TAP y D64, pero sin soporte para juegos multicarga...
A ver si @Naibor o @Zub comentan algo, que ellos estuvieron mirando mejor las especificaciones.
« Respuesta #282 en: Agosto 09, 2020, 14:49:29 »
La reseña de Commodore Spain
https://www.youtube.com/watch?v=-jxBpGACsmg
« Respuesta #283 en: Agosto 09, 2020, 14:55:15 »
Ahí se ve que ejecuta un PRG dentro de un D64 y luego funcionan las cargas dentro del juego.
« Respuesta #284 en: Agosto 09, 2020, 15:03:10 »
Ciertamente no son colores muy commodorianos... :D
