Autor Tema: Hardware nuevo para C64  (Leído 187988 veces)
« Respuesta #255 en: Junio 24, 2020, 20:21:45 »
Un teclado numérico para C64, es genial, sólo que poco práctico
« Respuesta #256 en: Junio 24, 2020, 21:53:23 »
Pero es de verdad? Al menos no se puede dudar de que es realmente retro  ;D
« Respuesta #257 en: Junio 25, 2020, 00:16:40 »
Yo creo que es de verdad pero tambien creo que es algo de coña :D
« Respuesta #258 en: Julio 04, 2020, 13:24:19 »
Poniendole teclado al TheC64 Mini...
https://bleughbleugh.wordpress.com/tag/c64-mini/
« Respuesta #259 en: Julio 28, 2020, 14:55:11 »
Aquí uno que está intentando crear una nueva placa base para 64, con muchas mejoras extras:
https://www.lemon64.com/forum/viewtopic.php?t=75106
1. Included both NTSC and PAL crystals between pins 13 and 14 of U31 (8701) and added jumpers to switch between them. There is also original PAL/NTSC jumper. I'm not really sure if this is enough. According to online conversion howtos, it is. Of course proper VIC must be inserted.
2. Removed RF modulator connectors and included replacement circuit.
3. Since modulator replacement already alows chroma and luma adjustments I also added circuitry for AEC and PH0 adjustement, thus LumaFix is included.
4. I've added jumpers to allow switching VIC voltage and pullup resistors so board will accept both 656x and 856x VIC chips.
5. I've added LM7809 voltage regulator to produce stabilized 9V for SID 8580. There are jumpers too to select SID voltage and filter capacitors so both 6581 and 8580 can be used. I'm not sure if 8580 need regulated 9V since it works from unregulated 9V on Assy no. 250469. I also replaced 5V input on pin 25 to CAN+5V. Hopefully regulated voltage will ensure a tiny bit higher audio quality Very Happy
Thats it for now. I'm also thinking about following changes for next revisions:
1. Adding S-Video port and audio jack, but this will need second smaller PCB to get sockets at proper height to match case holes (like in C64 Reloaded).
2. Getting rid of user port and putting S-Video and audio jacks there. Personally, I've never used it for anything other than C64 harness.
3. With user port removed it will be possible to built-in SD2IEC and put SD card slot there. But this is not priority for me as I use Ultimate 1541 most of time.
4. Replacing MOS 8701 with TOLB.
5. Replacing PLA with GAL PLA or some other PLA replacement.
6. Replacing DRAMs with something easily available (different DRAMs or maybe SRAM)
7. With user port removed perhaps switch to modern and more common 12V DC PSU. But I'm not sure what functionality will be lost or if C64 will work at all with just 12V DC input and then 12, 9 and 5 volts outputs, all regulated on board.
« Respuesta #260 en: Julio 28, 2020, 15:49:46 »
Hay una cosa que no entiendo: si le quita el user port, ¿cómo conecta el Ultimate-1541 que dice que utiliza?
« Respuesta #261 en: Julio 28, 2020, 17:30:51 »
Buena pregunta...
« Respuesta #262 en: Julio 28, 2020, 17:34:28 »
Le hice la pregunta, a ver qué tiene planeado.
« Respuesta #263 en: Julio 28, 2020, 18:05:33 »
Es que si le quitas el user port ya puedes olvidarte de usar Ultimate-1541, EasyFlash, Kung Fu Flash, Dead Test Cartridge, cartuchos de juegos,... Imagino que no lo quitará del todo porque se ven los agujeros en la placa, pero molaría saber qué solución aplica.
« Respuesta #264 en: Julio 28, 2020, 18:14:01 »
No sé si tiene sentido quitar el user port... con lo que mola enchufar cartuchitos!
« Respuesta #265 en: Julio 28, 2020, 21:46:13 »
Sobre todo los cartuchitos del Street Fighter II Champion Edition 😃
« Respuesta #266 en: Julio 28, 2020, 23:29:49 »
Me ha respondido:
- The 1541 Ultimate doesn't use the user port...
- That goes in the cartridge port.
Y aquí es donde me ha liado... ¿cuál es el user port entonces?
« Respuesta #267 en: Julio 28, 2020, 23:33:33 »
Supongo que el cartridge port es el de la izquierda y el user port es el de la derecha.
Que sinver :D
« Respuesta #268 en: Julio 29, 2020, 05:46:45 »
Ya estás haciendo lobby para que se haga cartuchito... :D
« Respuesta #269 en: Julio 29, 2020, 10:24:42 »
Upsss, cierto  :-X :-X :-X Me ha confundido la foto de la placa porque a la izquierda se ven el "user port" (que yo pensaba que era el expansion port o puerto paralelo) y el puerto de cassette, y el puerto que no se ve como tal es el de los cartuchos en la parte derecha, y como el autor decía que había quitado el user port... Ahora estoy aún más confundido, de hecho...
