Autor Tema: Hoxs64 Commodore 64 Emulator  (Leído 10324 veces)
Re:Hoxs64 Commodore 64 Emulator
« Respuesta #15 en: Septiembre 05, 2022, 04:04:50 »
Nueva versión:
03 September 2022 v1.1.1.1
1) Put back accidentally deleted SID player driver.
02 September 2022 v1.1.1.0
1) Fix corruption bug with the REU swap command. This fixes Sonic the Hedgehog by Mr. Sid.
2) Fix the joystick loading of settings to support a blank axis selection.
3) Set D64 sector gap to 7 bytes.
4) Drive motor linear spin up time added.
5) Drive VIA1 Port A improved simulation of floating pins.
« Respuesta #16 en: Julio 03, 2024, 05:27:13 »
Actualización Hoxs64 bit v1.1.2.6 10 June 2023
10 June 2024 v1.1.2.6
1) Fix C64 load a saved state regression bug affecting cartridges.
10 June 2024 v1.1.2.5
1) Fix REU file image truncation bug when loading a .REU file that more than 512kB and less than 16MB.
27 May 2024 v1.1.2.4
1) ImGUI remember directory path after closing the application.
2) New option to slow-load a host PC .PRG file via a more realistic 1541 disk load, instead of using instant memory injection. This is possible by both the user interface and command line options.
3) REU option for 16 megabytes of RAM. Ability to load .REU files.
4) Put back full screen pixel doubler option "1x" to turn off image stretch-to-fit.
5) Retro Replay cart bug fix stuck register DE01 bit 7: bank-address bit 15 for ROM banking.
07 March 2023 v1.1.2.3
1) Added missing keyboard assignment dialog key boxes for COMMA and DOT.
2) Improve unconnected IO emulation in the disk drive memory map.
