Pero hombre, cancela esa boda y ese viaje, hay que saber priorizar las cosas!
Eso, eso
Bromas aparte, que ya tiene bastante, el problema que tienes con el wav-prg es que tienes que bajarte el audiotap y descomprimirlo en la misma carpeta, lo acabo de comprobar, mira lo que dice en la web:
"Download WAV-PRG 4.2.1 for Windows, GUI version (tested on Windows 7 and 10) complete with plug-ins.
Note: This file contains WAV-PRG stand-alone. On its own, only reads/writes .TAP files. You need to download Audiotap and unzip it in the same folder (audiotap.dll is in both archives and it is identical) to support sound card and WAV files.
Download Audiotap 2.2.1 for Windows (tested on Windows 7 and 10)
Note: this package also contains some DLL files which enhance WAV-PRG, giving it the ability to read/write WAV files and the soundcard. If you downloaded the stand-alone version of WAV-PRG and want it to be able to do so, unzip it in the same directory where Audiotap and its accompanying DLL files are."
Y paciencia aún me queda un rato, tu no conoces a McGiver??
