Autor Tema: Chameleon  (Leído 48358 veces)
Re:Chameleon
« Respuesta #150 en: Enero 04, 2019, 12:57:54 »
Para quien esté interesado, Icomp está a punto de sacar a la venta la segunda versión del Turbo Chamaleon. Se puede reservar ya y podéis ver las diferencias respecto a la primera versión en estos enlaces:
https://icomp.de/shop-icomp/en/shop/product/Turbo_Chameleon_64.html
http://wiki.icomp.de/wiki/Chameleon_hardware_V1_vs_V2
Re:Chameleon
« Respuesta #151 en: Enero 11, 2019, 19:25:14 »
Re:Chameleon
« Respuesta #152 en: Enero 11, 2019, 20:41:34 »
Lindo cacharro este Chamaleon.
Re:Chameleon
« Respuesta #153 en: Diciembre 01, 2020, 11:25:19 »
Otra actualización disponible, la 9j
FPGA Core:
- on reset initialize CPU port DATA to 0.
- tweak ANE magic constant, fixes Spectipede and Turrican 3
- fixed "Nordic Power" mode in Retro/Nordic Replay emulation
- support "clockport enable" bit in Retro/Nordic Replay emulation
- added optional "B for up" for CDTV remote
- New SID emulation that uses lookup tables for the waveforms, resulting in more
accurate emulation of combined waveforms.
- Fix to get proper values for CIA alarm registers on reset
- Fixed off by one error in the envelope rate generator tables.
- Fix for envelope emulation when starting release while in the attack phase.
- A fix for dmadelay by introducing a delay on the colcounter and starting it
one cycle early.
Assumption is that in the real vic-chip the 10 bit screen address counter is a
ripple counter with extra latch on the output.
- New REU implemenation with prefetching logic to work around Chameleon SDRAM
latency.
This removes an unnecssary dummy cycle and makes the REU emulation cycle
exact.
- Fix REU memory access glitch by giving it one more delay cycle in the system
ram multiplexer. (a hidden bug now visible with previous fix)
- Fixed issue with REU trigger through FF00 while turbo is active.
- Fixed REU register default values after reset.
- Added support for Amiga keyboard connected to the docking-station
- Implemented reconfigurable PLL for the VGA clock. This allows the vga output
to better match the standard vesa resolutions.
- Added vga border option in register D0F2 to assist autoadjust on modern
displays (is active in bootloader and in menu during VGA mode test).
- New VESA video modes added and existing modes adjusted to better match
standard modes. Any non-standard 72 Hz modes have been removed.
- Added logic to select the proper sync. polarity for each VGA mode. Fixed
wrong sync. polarity on V2 hardware.
- Adjust pipeline length of hsync, vsync, ena_rgb to eliminate glitches on the
left side of the screen (was only visible on 1280x1024 resolution)
Menu System:
- BUGFIX: leave clockport setup alone on "Reset to Basic".
- BUGFIX: the filecopy feature of the file browser produced broken files due
to a compiler bug, which has been fixed.
- the easyflash EAPI sets the EF registers to the same values as the original
flash driver at exit of various functions. this increases compatibility
with some (technically buggy) programs that rely on these values.
- sysinfo also shows the current slot as letter
- During the boot loader and the VGA mode test a tiny white border will be
shown around the VGA display area, which will make it easier to adjust and
will make "auto adjust" work better.
Descarga desde la misma página de la WIKI: http://wiki.icomp.de/wiki/Chameleon#Updates
Se han arreglado muchos temas relacionados con la REU y la salida VGA. Además ahora se puede modificar desde el menú la funcionalidad de los 2 botones del mando CDTV con la posibilidad de usar el botón B como autodisparo o salto
Re:Chameleon
« Respuesta #154 en: Enero 28, 2021, 19:17:40 »
Y otra actualización mas. Van a 1 por mes  ;)
http://wiki.icomp.de/w/images/1/15/Chameleon_Beta-9l.zip
Menu System:
- extensive update to the help system contributed by Geert De Prins
FPGA Core:
- Fix in VIC-II emulation, Sprite vs Sprite collisions were wrong for some pixel
  values
- Fixed 512k Ocean Cartridge mapping
- When CPU is crashed, force a reset when pressing the menu button. Allows to
  enter the menu when CPU is crashed.
- Fixed REU behavior when triggered by a Read-modify-write instruction operating
  at FF00.
- REU timing fixes. The REU can steal one cycle during badlines or at the
  beginning of sprite DMA.
- REU/VIC-II combined timing fix. Added emulation of slow BA signal for the
  first sprite 0 DMA fetch, allowing REU to steal two cycles.
update.prg:
  - after successful update also delete the core file that was flashed
flasher:
  - fixed a bug that would result in the wrong core flashed to v1 hardware
Re:Chameleon
« Respuesta #155 en: Enero 28, 2021, 21:03:35 »
Sigue vivo!
Re:Chameleon
« Respuesta #156 en: Febrero 27, 2021, 11:16:04 »
Otra actualización mas desde la página oficial, Beta 9m:
Descarga:  http://wiki.icomp.de/w/images/1/10/Chameleon_Beta-9m.zip
Pocas cosas mejoradas. Intentan ahora sacar actualizaciones casi mensuales y dejar las betas ya que practicamente sus problemas e incompatibilidades con los d64 son inexistentes.
