Autor Tema: Nuevos cracks de juegos clasicos.  (Leído 95812 veces)
« Respuesta #45 en: Abril 21, 2017, 10:23:50 »
Hoy le toca a un peso pesado: Katakis.
http://csdb.dk/release/?id=155627
Parece que ultimamente los unicos activos son Hokuto Force y poco a poco nos regalan cracks de mayor envergadura. Espero que sigan asi mucho tiempo ;D
bovirtual
    • http://www.commodoremania.com
« Respuesta #46 en: Abril 21, 2017, 13:03:55 »
Bufff, juegazo. Este toca probarlo
Enviado desde mi Redmi Note 3 mediante Tapatalk
« Respuesta #47 en: Abril 25, 2017, 22:39:52 »
Y otro juegazo gracias a Hokuto Force: The Last Ninja II
http://csdb.dk/release/?id=155742
« Respuesta #50 en: Junio 16, 2017, 15:32:31 »
Rogue +6DGM: http://csdb.dk/release/?id=156806&show=summary#summary
No conocía el juego, supongo que será un "roguelike".
Me llamó la atención el comentario que pusieron:
The C64 conversion of Rogue is a buggy
incomplete game. Many of the lines of
text that can be found in memory are
never used, and the advanced features of
scrolls and potions (and searching) do
not work like the original.
In fact, there a few fatal bugs that
make it so the game can never be
completed.
The original quest of Rogue is to find
the Amulet of Yendor in a dungeon at
least 26 levels deep and bring it back
to the surface.
For this Hokuto Force version, we found
and fixed the code that enables
collection of the amulet and unlocks the
ability to go back up stairs.
You can now see the winning game message
Here’s what was fixed:
- RESTORED missing Amulet of Yendor
(looks like a ring somewhere on level
26 or higher)
- FIXED bug which increased levels using
decimal math mode - this caused dozens
of levels to be skipped, ruining most
chances of ever reaching the amulet
- FIXED load/save game routines, which
never worked correctly - switched to
support saving to disk (using drive
number game loaded from)
- FIXED bug with item names using text
out of range - this corrected several
ring names
- FIXED bugs with random number
generation that could lock up the game
- FIXED interrupt and timer init that
would sometimes freeze the game
- CLEANED raster split and removed
several graphic glitches
- REMOVED garbage graphics during screen
transitions and game-over messages
Added 6 trainers:
- No damage from monsters
- No drain on strength as time passes
- Maximum HP (weapon strength)
- Maximum armour
- In-game level skip using +/- keys for
level down/up
- Choose starting level
Plus, added one enhancement:
- The original game had no music at all
and barely any sound effects, so we
added a completely optional bonus
music track by Linus.
Press ‘M’ anytime during the game to
turn music on/off.
« Respuesta #51 en: Julio 17, 2017, 17:09:23 »
Otro de esos clasicos que nunca fui capaz de comprender en su dia:
Feud
Ahora el nuevo crack de Hokuto Force incluye un mapa en png.
http://csdb.dk/release/?id=157388
« Respuesta #52 en: Julio 17, 2017, 18:33:13 »
El feud era otro juego chulo de dar vueltas con música guays.
Lo mejón
Zub
« Respuesta #53 en: Julio 25, 2017, 23:58:53 »
Yo soy un gran estudioso de Feud. Lo tuve en cinta y siempre me encantó la ambientación con la música lúgubre y la oscuridad del bosque.
El juego tiene alguna cosa curiosa. Los fondos son bitmap multicolor e implementaron una lógica para gestionar la prioridad Z de los sprites (si están delante o detrás del bitmap, en función de si pasas delante o detrás de un objeto) lo cual no es algo sencillo. Hay algún ejemplo como Last Ninja que recorta los sprites cada vez que pasas detrás de algo, o el Airborne Ranger que lo hace sólo usando los registros hardware ya que los gráficos son muy sencillos. En el Feud, hace una mezcla de ambas técnicas que funciona más o menos.
Desgraciadamente, el programador se debió quedar sin tiempo porque el juego está sin acabar. Aparte de bugs horribles (el hechizo Sprites produce un crash, esto lo han arreglado en este crack)... Pero lo peor de todo es que el espíritu de la versión original de Spectrum se ha perdido. El enemigo deambula sin lógica alguna por el mapa, atravesando obstáculos y sin seguir estrategia alguna. Vencerle es casi más cuestión de suerte que otra cosa...
« Respuesta #54 en: Julio 26, 2017, 01:24:34 »
Nunca lo he jugado.
Este tema me resulta muy interesante, hay juegos que hacen unas cosas increibles y me cuesta entender cómo han hecho que el sprite pase por delante y atrás del escenario.
« Respuesta #55 en: Agosto 29, 2017, 21:34:42 »
Nuevo crack de Summer Games I & II por Wolf:
http://csdb.dk/release/?id=158497
« Respuesta #56 en: Octubre 31, 2017, 15:52:33 »
Otro crack de Wolf y Hokuto Force, un autentico clasico: Ant Attack
http://csdb.dk/release/?id=160126
« Respuesta #57 en: Octubre 31, 2017, 17:43:24 »
Llevo viendo este juego desde los inicios de los tiempos pero nunca lo he jugado...
Zub
« Respuesta #58 en: Octubre 31, 2017, 19:59:45 »
El primer juego que tuve! Me vino incluído con el C64.
Nunca me gustó nada, la verdad.
« Respuesta #59 en: Noviembre 01, 2017, 10:13:52 »
Nunca jugue al Ant Attack en su dia, me parecia un juego de Spectrum...  Aun asi la idea estaba bien, despues me desquite con el It Came from the Desert de Amiga.  ;D
